Fabia Mk3 Bolero (P0369T): Android Auto, wireless dongles and Bluetooth all stopped working. Reflash refused, 0480T won’t instal
Hi all,
Android Auto worked fine in my Fabia Mk3 until 7 November 2026, then stopped. I hadn’t made any changes. I’ve been through everything I can find and I’m stuck.
Unit
  • Skoda Fabia Mk III, Bolero (MIB2 Standard, Technisat)
  • SW train: MST2_EU_SK_ZR_P0369T
Symptom
  • Android Auto on the phone detects the car and tells me to go to the head unit to continue.
  • The head unit then abandons the connection and drops. The screen shows MirrorLink, then it disconnects.
  • It then re-initiates the sync over and over and never gets anywhere.
  • It’s the same across multiple phones and multiple cables. I’ve cycled through the cables.
  • I suspect something at the protocol level.
What fails
  • Samsung S24 Ultra, wired, with several known-good cables
  • Samsung Galaxy A8 (2018), wired: Android Auto won’t initialise
  • Two different plug-in Wi-Fi Android Auto dongles: each one attempts, sees the phone, then abandons
  • iPhone (a passenger’s) over Bluetooth: it pairs, the car presents it and there’s a handshake of some sort, but audio and other functions won’t connect. The passenger tried several times without success.
What I’ve done on the car
  1. MENU > SmartLink > Android Auto, selected manually
  2. SmartLink reset
  3. Factory settings > Restore factory settings (full reset); all settings cleared and everything re-paired from scratch
  4. Reflash of MST2_EU_SK_ZR_P0369T from SD (FAT32, files in root): the unit won’t accept it
  5. MST2_EU_SK_ZR_P0480T from SD: doesn’t work
What I’ve done on the phone (S24 Ultra)
  1. Cleared the Android Auto cache and all settings
  2. Uninstalled and reinstalled Android Auto updates; phone fully updated
  3. USB data to a PC works, so the phone’s port is fine
Tools: OBD2 reader only. Probably dead, a cheapo clone. No VCDS.
Similar threads I’ve found
My questions
  1. Has anyone had Android Auto, Wi-Fi dongles and Bluetooth all fail together on a Bolero, with the sync looping like this? What fixed it?
  2. Is there a way to force a reinstall of P0369T without VCDS?
  3. Does this point to a failed glove-box unit, or something at the protocol level?
Thanks.
Edited by yewneek
detail
Yes. Typical problem is either FEC/SWaP corruption or EMMC failure. Pls go to service menu (long press MENU button) and check what are installed FEC/SWaP codes and if they are valid.
Recently Browsing 2
