Rear doors/Fuel cover will NOT lock!!
Can anyone offer any advise on the title, my rear doors or fuel cover will not lock!!
I have done a fault check and the only faults to show are LEFT/RIGHT Cabin Heaters No Signal, in the (09) Central Electrics code B149F31 which is not showing anything on a search.
The alarm still works, but the little red indicator light flashes rapidly for a few seconds then steady on for 30 odd seconds then resumes normal rhythm.
My car is a 64 (2015 model) Vrs Tdi Estate, no other issues if that helps, ive done searches everywhere but nothing is popping up.
Ive locked them for now using the little switch inside door to prevent them being opened.
Do they lock if you use the central locking button near the gear lever?
Do the power windows still work on those doors?
TMac88,
No the button does not work either, nor for autolock (except when I deadlock the rear doors).
The powered windows still work on all windows.
Ive checked fuses, disconnected battery for an hour (which threw up loads of faults) to no avail as yet.
Dez
Edited by DEZMONDE
extra info
Do the rear door modules show in a VCDS scan - they should be sub modules of the front door module (here are mine):
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 E    HW: 5Q4 959 593 B
   Component: TSG FS        010 0032
   Serial number: -
   Coding: 001D0020D001040000001100
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 47C853C9FF2C40191933-8012
   Drivers Door Rear Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0005
   Serial number: -
   Coding: 1D0200
No fault code found.
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 E    HW: 5Q4 959 592 B
   Component: TSG BFS       010 0032
   Serial number: -
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 46D65ECDF8265911E245-8012
   Passengers Rear Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0005
   Serial number: -
   Coding: 050200
   Serial number: -
   Serial number: -
   Coding: 1D0200
   Serial number: -
   Serial number: -
   Coding: 050200
Thanks, I'll try check it out tomoz.
Only got obdeleven so hopefully get some results
@Gti Jazz BlueHad A look at the coding, mine are below. Not too much difference, the differences I have highlighted in BOLD.
   HW: 5Q4 959 393 B - VER 009
   SW: 5Q4 959 393 B - VER 0014
Component: TSG FS
Coding: 001C00208001040000001100
   Subsystem 1 -  HW: 5Q0 959 812 A
   Coding: 1D0200
   HW: 5Q4 959 392 B - VER 009
   SW: 5Q4 959 392 B - VER 0014
   Component: TSG BFS
   Subsystem 1 - HW: 5Q0 959 811 A
   Coding: 050200
I am stuffed as to where to go now.
Kev
Fixed the doors, 09 central electrics, long coding byte 02 bit 5, unticked that (Not sure what it does) result doors now work.
Still throws up the faults for cabin heater left and right though.
