P0405 EGR sensor 1 fault code 1.2 tdi
Hi all got a fault on my 1.2 tdi ecomotive CFWA engine
 btw it is a Seat Ibiza 2011 so should be safe as Fabia engine
15536 Egr sensor 1 P0405 00 (175) signal too low
Cleared it but comes on after a couple of ignition cycles
Any ideas of this fault?
Following, been having the same with my 11 plate 1.2tdi greenline fabia
Be worth checking the wiring / plug to the EGR valve, and may also be worth removing the valve and cleaning it......they can get very gunked up.
