Xenon light problem
Hello guys,i  recently got my clutch done,but when i got the car back my xenon lights are real low,when i turn on the lights the lights does the movement but still the lights are real low on dip and heads,anyone know what the problem might be?any info would be great.Thanks guys
If there's any fault in the system, the controller will point the lights fully downward by default to prevent other drivers being dazzled.
The most likely cause here is that the suspension level sensors were damaged or dislodged while the gearbox was being removed. The only other thing I could think of is that the person doing the clutch replacement decided to adjust the lights while he was at it and did a **** poor job of it. The next step really is to do a fault scan on the lighting controller using VCDS or similar.
More than likely they have forgot to bolt the sensor arm back onto wishbone
