wind deflectors
I have fitted these and had no problems re scratching.
A friend of mine lost the clips when he was moving his deflectors from one Yeti to another, so he used 3m double sided tape and found it worked very well.
I never use the metal clips, just peel the backing off the tape and push them into place
thanks guys. is the tape easy to remove if i remove deflectors at some point.
Yeah just pull the deflectors back out when you no longer need them
