Fault codes p0668 p2146 p2149
I have a no start issue that’s killing me any had this problem before?
  • 9 months later...
Have you found what the problem was? Mine is exactly the same
See here...
http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
Possible Symptoms
- Malfunction Indicator Lamp (MIL) active
Possible Causes
- Mass Air Flow Sensor (G70/MAF) or Intake Manifold Pressure Sensor (G71/MAP) faulty
- Dirty or faulty throttle body.
- Vacuum leak.
Possible Solutions
- Check Mass Air Flow Sensor (G70/MAF) or Intake Manifold Pressure Sensor (G71/MAP)
- Clean Throttle Body and perform Throttle Body Alignment (TBA).
- Check intake system for leaks and un-metered air. This includes Intake Manifold Runner(s) and Intake Manifold Runner position sensor(s) when applicable.
Edited by silver1011
