DQ200 Clutch Replacement
Good evening/morning!
I've just received my Octavia back from service after the mechatronics replacement. Everything is fine with it now thankfully. However, unfortunately, the clutch on it is gone - it was already pretty bad before my mechatronics gave out, but by the time I managed to safely pull over the clutch was well roasted. They made a comment about how the clutch is not far from it's end of life, and quoted me $4000 NZD to do it.. Nevertheless, I'm looking at options for clutches. It is the DQ200 transmission (dry clutch :sweat:). I've had a look at Dark side's kits but they don't seem to offer one specifically for the 1.6 Tdi with the 7 speed, only the 6. I'm wanting something that isn't rubbish quality, but also doesn't cost half the car's value.
Anyone have any suggestions for clutches?
Exact model: 2011 Skoda Octavia, 1.6Tdi. 7 speed DSG: OAM/DQ200.
Thanks!
@marfrohun
Did you find out if your car was recalled by Skoda NZ in 2012 and received the Service Campaign actions, so a new Mechtronic Control Unit, Mineral OIl and a Software update?
Did Skoda NZ / VW give a Warranty Extension in 2012 on DQ200 DSG's in New Zealand?
17 hours ago, Skoffski said:
http://hp.net.au
http://tvsengineering.nl/en/gearbox/dsg/dq200.html
In the UK is is around £1,700 to have the clutch packs replaced with OEM.
15 hours ago, xman said:
Manufactured until 5/2011
Manufactured after 5/2011
Check part nos carefully
Thank you!
15 hours ago, Skoffski said:
@marfrohun
Hello again Skoffski, I'm still trying to contact the old Skoda service up north that did all prior servicing to my ownership. However, my guess is not. I know I got the software update but not a new Mechatronics unit. Skoda seems to be awfully quiet in regards to the matter, however. I'll let you know when I find out any details! :)
