Anyone with VAG-COM / VCDS around Reading, Beekshire
Having replaced Exhaust Pressure Sensor recently, I learned that, to perform optimally, it needs to be "adapted" using couple of commands via VAG-COM. I don't have it. Is there anyone in or around Reading with genuine VAG-COM who can help please?
Did you try looking at the VCDS list and the VCDS map to find a local member?
Both can be found in this section of the forum :)
Thanks for the links. I have now contacted couple of local members via the map. Hope they are still actively using the forum.
