VCDS 18.9
I did all the VCDS mods as per my sig. using VCDS 18.1. with a genuine HEX-USB+CAN cable on my 2017 Octavia SEL 1.5TSi DSG. Today I wanted to change the threshold of the high beam activation but let VCDS update before I started. Now all I get is Ross-Tech USB Interface Not Found USB Library Version 03.02.07.
I am running Windows 10 and Ross Tech offer a work around which doesn't work for me so before emailing them does anyone else have this problem?
AFAIK, the workaround is normally sufficient.
If it's not working, the best plan is to contact rosstech as it could be something they've come across before.
Solved by Ross-Tech Forum.
Un-installed everything Ross-Tech - on my laptop - disabled "Core Isolation" from "Windows Security" within settings re-installed and was up and running within minutes. I now have my HBA coming on at speeds above 10mph and off at speeds below 5mph.
