can i use a needle to adjust the front nozzles?
hi guys
i was wondering if i can adjust the front nozzle?
i have read somewhere that you cant.
need clarification please
many thanks
  • Sponsor
Non-adjustable as far as I know.
thank you so i will need to buy the nozzles? is it easy to replace?
  • Sponsor
What's the problem you're trying to solve? Aim? Lack of flow? Are we even talking about the same thing, I interpreted what you asked as being about the windscreen washing nozzles?
yes its the nozzles direction i need to alter.
the left side is spot on but the drivers side is bit too low
14 minutes ago, Wino said:
thank you very much! will have to sort it tomorrow now. bit dark.
A pin gently pushed into the nozzles may dislodge any sh-huff thats accumulated in there. They will then most likely work better. I think some had adjustable but not all. I can't remember if perhaps heated ones were and non heated ones were not but I am fairly confident there were 2 versions.
That said, they are quite a cheap easy replacement too, if too blocked etc.
Deffo adjustable up the rear!
Edited by mrgf
