Enable Exterior mirror Lights
Hi! Can someone help Me with the encoding to activate the lights under the exterior mirrors on a Superb L&K 2016?
As you're not from the UK your specs may well be different but I always thought that the folding door mirrors had the puddle lights already fitted?
Do yours fold?
I do not know why they are not activated! I have all the lights but they are not activated under the mirrors. The lights are there but they do not turn on. I thought someone knew how to do coding with vcds. There has to be a coding!
Is it not a setting in the car menu's?
Hello ! Thank you for the question, but I did not find one. If anyone has a picture with the setting in the car menu I would be glad to see it! Thank you !
Doesn't they illuminate when you unlock the car at evenings or mornings when it is still dark? If you have activated coming/leaving home they should work together. I have deactivated coming/leaving home and they still work without the short beams and back lights.
