Multifunction steering wheel and head unit
What multifunction steering wheel and media head unit would work well on a Octavia mk2 face-lift? Wanting something with Bluetooth and for it to work with the wheel functions
Forgot to add, been thinking about the columbus and the 3T0419091K wheel but I'm not sure if this one's is compatible
Columbus doesn't have Bluetooth, but you can add a Bluetooth module to the car which will interface with the Columbus
Assuming your headunit is stock, then it should support a MFSW and BT (by adding the right module). It might help if you confirm what you've currently got fitted.
I think 3T0419091K looks right, a wheel from a MK2 FL Octavia, MK2 Superb or Yeti should work. Although if you don't have a maxidot instrument cluster, only the left hand buttons on the MFSW will work ;)
