Park/steer Assist error (VCDS)
Been a busy few weeks, what with a repairing front coil springs,full DIY service, etc. Car is a 1.6 TDI Fabia (105PS).
Not sure if it's related, I changed the fuel filter today - and the damn thing wouldn't start. I wouldn't mind but, I topped up the filter with fresh diesel. As I was cranking it  - it sounded 3 warning chimes. This car has done it to me before. I cycled the ignition a few times, with the battery on charge (still connected) and then fired it up.
I used VCDS (should have used that in the first place) to prime the filter and the following code is there:
Address 10: Park/Steer Assist (J446)       Labels:| 5J0-919-475.clb
   Part No SW: 5J0 919 475     HW: 5J0 919 475
   Component: PARKHILFE 4K  H10 0002
   Revision: --H10---    Serial number: 76231008302939
   Coding: 100001
   Shop #: WSC 13765 790 00048
   ASAM Dataset: EV_SK25XParkiAssis2 S01002
   ROD: EV_SK25XParkiAssis2.rod
   VCID: 72BED34B74232527989-8026
1 Fault Found:
1458176 - Internal Control Module Memory Check Sum Error
          B2000 46 [008] - Calibration/parameter memory failure
          [Steuergerät defekt - Fehler im EEPROM]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 2
Any pointers for me to check please. I tried to clear the error - but it remains.
Edited by spartacus68
Is this a result of recoding anything? I lost my park  assist after coding something unrelated.
No coding. I posted the same question on the VCDS forum and someone suggested disconnecting the battery for 10 minutes, which is a good call. I've still to do that.
