Climate control query
I’ve just purchased a 64 plate yeti black edition and the drivers side temperature control doesn’t work
is there any trick as the car didn’t come with a manual
warranty? sounds like a flap not working or temp sensor!
That's a very open ended statement. How does it not work? Does the dial not turn, are there no lights on the drivers side, is there no air coming out of the vents on the drivers side, is there no temperature change when you turn the dial up and down, does the temperature change but the air flow doesn't adjust at all?...
