Are Skoda Octavia's compatible with MIB 2.5 Golf units?
Hi,
I'm in the process of buying a Skoda Octavia vRS (MY16).
The seller has stated it has a 8" Columbus infotainment system - but it doesn't have Android Auto.
I take it that means it likely has MIB1, correct?
I'm keen to retrofit it with a newer unit that has Android Auto support.
In 2019 - what are my best options here?
I was told by a local car upgrade place that the MIB2 units from the Golf 7 will work:
https://eurocarupgrades.com.au/volkswagen-golf-7-mib2-discovery-pro-navigation-retrofit-8-2018-maps-oem-genuine-vw.html
But I see there's also MIB 2.5 units - e.g.:
https://eurozonetuning.com/products/mk7-5-mib2-5-discover-pro-9-2-retrofit-kit
Would this also be compatible with a Skoda Octavia? Any other caveats or things I should bear in mind?
Thanks,
Victor
It’s always better to get a proper Skoda one as the correct HMI is loaded on the unit but there is no reason that can’t be changed. I have a MIB2.5 Columbus in my car and it’s great, not cheap, but great :) If the car you’re looking at is MY16 then it will be a MIB2 and should have the option of activating SmartLink in the menu. It’s £137 for the activation from Skoda. If the radio doesn’t have this option then the car is older than MY16. Do you have pics of the radio or model number?
