Fault code city, on a mission to remove them all!
After my success today with the heater motor flaps one resident fault code is banished but there are many others I want to see the back of, some I have always had, some may be as a result of things I have done and others have appeared since fitting a Chinese head unit, lets start by seeing if I can copy and paste a VCDS auto-scan, I'm not good with computers but here goes:
Wahay its worked, - no it hasn't, it does not have the detailed fault codes.
try again:
Sunday,02,June,2019,20:12:34:21454
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
Dealer/Shop Name: Coquelicotel
VIN: TMBGS21Z862234806   License Plate:
Mileage: 211880km-131656mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72 76
VIN: TMBGS21Z862234806   Mileage: 211880km-131656miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Not registered 0011
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 016 CB    HW: 028 101 190 0
   Component: R4 1,9L EDC G000SG  6176
   Revision: 12345678    Serial number: XXXXXXXXXXXXXX
   Coding: 0000071
   Shop #: WSC 01392 785 00200
   VCID: 6597B290C964FACF0DB-8030
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   Shop #: WSC 73430 790 00000
   VCID: 3FDB40F80B78801FA77-806A
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 H
   Component: ClimatronicPQ35 084 0305
   Shop #: WSC 00000 000 00000
   VCID: 3B2334E81F609C3F8BF-806E
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000003929087
   Coding: 41080E231004140000110D000000000000087F0700
   Shop #: WSC 73430 790 12345
   VCID: 2B0304A8EF000CBF1BF-807E
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00065525
   Shop #: WSC 73430
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00471077
   Shop #: WSC 73430
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 R    HW: 1K0 909 605 R
   Component: Q4 AIRBAG VW8   018 2200
   Revision: 02018000    Serial number: 0038MD08DT2C
   Coding: 0020788
   Subsystem 1 - Serial number: 6332MSME0E286307B
   Subsystem 2 - Serial number: 6342MSME0E284D15J
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 034 0070
   Coding: 0000042
   VCID: 76B5E5DC64C20157B41-8022
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1Z0 920 941 E
   Component: KOMBIINSTRUMENT VD1 0920
   Coding: 0001401
   Shop #: WSC 28060 067 57207
   VCID: 392F2EE0155CAE2F993-806C
1 Fault Found:
00003 - Control Module
            014 - Defective
Address 19: CAN Gateway        Labels:. 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 080408F2008378
   Coding: E9807F0E0002022302
   Shop #: WSC 00066 000 00000
   VCID: 303913C4C6266F672ED-8064
2 Faults Found:
01304 - Radio
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 213
                    Mileage: 211885 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:59:58
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 5
                    Reset counter: 255
                    Mileage: 211885 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:59:08
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 0920
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2346
   Coding: 0000758
   VCID: 363525DC24424157741-8062
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V2.clb
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 34311FD4323E53474A5-8060
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 00D002007F2D8505481F861004CC
   VCID: 79AFEEE055DC6E2FD93-802C
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE No Answer
2 Faults Found:
01135 - Interior Monitoring Sensors
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1T0 959 702 B
   Coding: 0000758
   VCID: 372B28D82348B85F6F7-8062
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 1K0 959 703 E
   Component: Tuer-SG         021 2435
   Coding: 0000144
   VCID: 323D19CCC82A5D77589-8066
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 1K0 959 704 E
   Coding: 0000144
   VCID: 33331CC83730547F53F-8066
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0000001
   VCID: 3D273AF00174920FB5B-8068
End----------(Elapsed Time: 00:58, VBatt start/end: 12.4V/12.4V)-----------
Edited by J.R.
Starting with an easy one, the instrument panel, control module defective.
I think this has always been there but its just possible it only started when I swapped the ECU for a remapped one that had the immobiliser defeated to make it plug and play.
Any ideas?
And with the ECU change in mind it may have had an effect on the alarm controller fault codes, it always had the non comm error because the internal battery had leaked over the circuit board, I replaced it with a new Chinese one from Ali-Express to get the same fault code plus then the interior monitoring sensor fault, it is just possible that this coincided with the change of ECU and whatever they had done to defeat the immobiliser.
Given that i no longer have an immobiliser, the alarm is not functioning despite the new siren, if no-one can suggest how to fix it can i not recode the vehicle to say it does not have an alarm/immobiliser and get rid of the fault codes?
I have seen a coding checkbox in the can bus gateway controller for immobiliser, i ticked it when recoding the new one as it was ticked on the old one, does immobiliser mean alarm as well and could I just untick it?
Now for the fault codes that started when I fitted the Chinese head unit which has Satnav on a micro sim card.
01304 Radio, no communication.
OK I understand that, its no longer there, on the old canbus I tried coding it out but then the new unit would not switch off with the ignition, is there a solution to retain the functionality but remove the faultcode?
The head unit interpretes the can bus signals for switch off, wake up, doors open, reversing sensors etc but clearly does not talk back to the gateway controller.
Control module incorrectly coded, not a lot of use unless I know what is incorrect, I just ticked the options that the older revision unit had coded in.
Adress 37 Navigation cannot be reached.
It seems to think that navigation is fitted but cannot communicate with it, this happened also with the original can bus gateway, navigation is definitely not ticked on either of them.
Address 56, radio cannot be reached; - ditto.
I was so jealous when I scanned my neighbours 2012 Octavia, not a single fault code, recently mine with the old can bus gateway not switching the head unit off I had fault codes on all but a couple of controllers.
My aim is to have none, since owning the car they are apppearing faster than I can resolve them although many are probably down to the changes I have made like the remapped ECU and the head unit.
I don't think it'll ever be fault free given what you've had done.
Add 37 to the installation list in the CAN gateway.
01304 - Radio
Cannot be reached
Address 56: Radio
Cannot be reached
Are due to the aftermarket radio, for it to turn on/off you need to keep them in the installation list so you'll always have faults.
    014 - Defective
Is likely to be due to the immo removal, again, not much you can do unless you get the immo sorted.
You can either fix these or try and code them out. Should be pretty obvious which bits need checking/unchecking from the descriptions :)
What module do I code them out of?
Canbus gateway has an address for "immobiliser" but dont know if that includes the alarm?
I came to the same conclusion regarding the radio.
Hopefully tomorrow the voltage wont have dropped any significant amount.
Probably 46 at a guess? Otherwise maybe 09.
Removing 25 will give you an error so it won't help. When the immo was removed, some number of checksums have been messed up in the instrument cluster EEPROM. The only was to remove the error is to fix the immo data and checksums.
So I believe they are the module numbers where you think I should look for addresses to recode, is that correct?
Add 37 to the gateway............
I think you mean to tell it that it has navigation fitted, I'm sure I tried that with the old module but will try again.
You think the instrument cluster control module defective code is due to the immobiliser being bypassed in the ECU, is that correct?
The immobiliser defeat would have been on the engine ECU though, shouldn’t effect the dash cluster. Should still be operating on immo 2 effectively.
What is "immo 2" please?
Level 2 immobiliser. Dash and key transponder.
Level 3 onwards would be dash, key and engine ECU.
I thought the MK2 Octavia was immo4?
2 , 3 or 4 I dont understand Techie's comment or its relevance, that the dash cluster should be working on immo 2, what does this mean in relation to my getting rid of the fault code that says the dash cluster is defective or uncoding the immobiliser and/or alarm?
What I mean is you can defeat the engine side of the immobiliser and it should have nothing to do with the dash cluster. The fault code you have is to do with the dash cluster itself, not the defeat.
