Airbag light/ Horn /steering wheel controls not working
Hi Everyone - Can someone help please. Our 2011 Octavia has an issue (first in ages to be fair) -
The airbag light comes on at start up, and the horn/other electrics are not working.  I was hoping it would be a fuse - but I tink it's worse than that.
Can anyone provide some assistance please?
Thank you.
Mantrahalos.
Fault code scan, see if there is communication with the column control unit.
Thanks for the response Tech1e.
Is this something I am able to do myself, or does it need to go to a garage?
Do you have diagnostic equipment that can read the control units?
Hi again Tech1e.  I do not - So I'll have to take it somewhere to get looked at.
I've done a little more research and it sounds like it is the clock spring that is broken and needs replacing
That is the most likely candidate but a diagnostic computer will be needed to clear the fault code anyhow.
