Swimming in my Yeti!
Sorry all, it’s been a while since I posted anything. In fact years. In part because the Yeti has performed faultlessly in the now six years of ownership.
HOWEVER  - this last few days I noticed water on the front passenger rubber mat. On further investigation, the carpet underneath was sitting in water. Have tried to soak up as much as possible (1 1/2 kitchen rolls worth), but as we are away from home, I am limited as to what else can be done just now. Yes the car has a panoramic sun roof. Door seals appear ok and well seated. No loss of radiator water.
would very much appreciate any advice. Thank you.
Blocked sunroof drain pipes.?quite a few posts on here for reference.
Edited by Sad555
Cracked sunroof frame, thats been on here as well
If you have dried up most of the water, you could try getting a syringe and deliberately trying to make it wet again!  Open the sunroof and find one of the drains and identify where it should come out (there's threads on here with photos with headlining etc removed of the routing of the drain pipes and where the exit holes are).  Pump a syringe full of water into the first sunroof drain and check water comes out the correct hole at the bottom, repeat for the other drains until you find one that doesn't give up any water.  That will be the culprit, pop another few doses of water in and confirm the carpet is getting wetter.  If away from home you could then bung up that drain hole until you get back home and are able to get it fixed properly.
Thanks to Sad555  Kenfowler and widdershins. Have managed to tilt car both ways, with roof open, and on drivers side using a watering can, all comes out the round bung 3/4’s down the A post. However on the passenger (problem) side no water exits the bung outlet at all - goes straight under the carpet!
Having tried to see the drains in the sunroof frame, I had assumed their only to be one. Must read up on the threads now to see what you mean widdershins. Thank you.
Sorry guys, have tried all combinations of ‘Yeti sunroof drains blocked’ in the search box, and comes up with nothing.
Would appreciate some guidance please on how to find previous posts on this subject 🤔🤪
In your search engine write "Briskoda, Yeti sunroof drains" and that will bring up numerous threads. Click on each one to read.
Thanks so much Llanigraham. Got it!
Any thing for another Spridget owner!
Thought I recognised you from M.A.S.C.!
You did.
My car was in the Introductions section a couple of months ago.
Spridgetman..."YouTube can be handy for video explanations of issues.
