Air con issue
Hi I recently had my air con regressed with no issues and leaks being shown. Its at the requiredevel it should be at but my air con is still not working. The fans are running behind the radiator. The garage told me once they were working my air con would work this isn't the case. Have checked the fuse which is ok. Not really sure what else to try if I'm honest. It's a skoda octavia 2010 vrs. Any help and advice would be much appreciated
Will need diagnostics plugging in along with an air con machine and seeing what’s happening.
Check the center bolt hasn’t came out of the compressor clutch. You can get new clutch kits off eBay for them
It’s a variable compressor, it doesn’t have a clutch.
The shaft nut can still come loose and the splines then strip in the aluminium centre boss, even on a new compressor.
Please dont ask me how I know 🙄
