2011 Fabia cambelt and water pump
Am going to look at a 2011 Fabia tomorrow. It has very low mileage and a full main dealer history. Does that model use a cambelt rather than a chain and if so what are the change intervals - mileage or years please? ShoUld the water pump be changed at the same time? TIA.
Don't know; that will depend on the exact engine (code, not just fuel and capacity) fitted.
On a lot of the cambelt engines, the water pump has a life typically 1.5x the cambelt change interval, and you need to change the cambelt to replace the water pump, so you save time and money by getting a new pump done when the belt's off anyway.
It’s a 1.2 Diesel engine if that helps.
CORRECTION. It’s Petrol!
That’s a chain then
And as charitable as I am, for not giving engine details, then giving the wrong engine details when asking for help you get a meme
I am truly humbled. Thanks.
