How to see litres of diesel used on a trip?
Hi all,
After being in a friends Megane I tried but couldnt find the same function on the Superb.
How do you see, in liters or gallons etc how much fuel you have used between point A and point B??
Many thanks
Not sure which version you so this might not work
on the right thumbwheel scroll to where it shows mpg etc
press and hold down the thumbwheel, then scroll, should offer different variations eg since start, since last refill, long term (which I think is capped at 2000 miles)
If you are wanting litres rather than gallons, I think you have to go into infotainment, car settings and change from imperial to metric (but I don't think you can mix litres and miles as changing it to metric changes to km), but haven't checked.  If so just use the mpg setting and divide by 4.54609
Thanks for getting back to me .
Unfortunately that just shows different types of MPG etc and not just liters used.
Must be a different system.
Thanks all the same
If you want an actually accurate figure, points A and B must both be filling stations. Fill to the click at A, drive to B, and fill to the click again, Note the fuel delivered at B.
Anything else will be subject to the vagaries of the trip computer.
The only thing I know, is to enable the "Refuel quantity" in the maxidot. But this is a very rough value, which is only refreshed every 5l. Not what I had imagined, quite useless in the end... I may disable this function...
This been said. It's not from point A to point B, it only tells you how much is missing for full tank (at least up to the clic).
Edited by Bap33
