Usb bluetooth adaptor
Hello all, im new to skoda so hopefully somone will be able to help me out.
Firstly my 2012 monte carlo has a sat nav headunit  but  the maps are on a disc so to listen to a cd i have to do without nav. It has a sd slot on the unit, surely this was meant for the maps and not the cd slot.
Also if i use a usb bluetooth adaptor  can i stream music from my phone .
Thanks in advance.
You can save the maps to the hard drive, so you can use the CD slot for music.
If the Sat nav has bluetooth and the phone module is in the car, you don't need an adpator
I dont think mine has a hard drive its the 310 not the 315 model head unit.
Try copying the map disc to the SD card then.
Cheers.
All sorted, copied disc to sd card. Thanks for your help.
np :thumbup:
