stereo
hi guys ive just had a kenwood dab stereo fitted to my skoda fabia 2002 works fine but need to put a constant feed on it to keep memory.Whats the easiest way to do this
Reverse the yellow and red wires, it's been fitted incorrectly.
Would I be able to cut the two wires and reconnect to red/yellow
That you have to ask suggests it may be beyond your capabilities, joking aside, make sure you disco the battery first since one of them is a permanent live and in-car electrical fires always look unprofessional.
Pull the fuses first. Do NOT cut the wires. Use a paper clip to release the wires from the connector and swap them.
<Rewind> If you've had it fitted, who fitted it. They should have checked power availability (i.e. fuses OK) and swapped the wires over (or used and adapter harness). If it's Halfords, suggest to them it's been done wrong and they should fix it.
thank you i never thought of that will do that later
