Gearbox problems.
Hi,
I had this problem today which I have never experienced on a car before.  I came around a roundabout in 2nd gear went to change to 3rd gear but could not as the gear lever was jammed. Their was no play what so ever it was solid. I still had the clutch still depressed so brought the pedal and it was still working as the engine started to stall. I kept trying to move the gear lever and eventually it moved and is working fine as if nothing happened. I am hoping might have an answer to this problem.
Many thanks
john42.
Try resetting the gear linkage, if that doesn't help then it's not looking good for your gearbox internals but top up the gearbox oil anyway.
Edit: Double post, you already have these answers in your identical twin thread.
Edited by sepulchrave
