magnetic clutch for super charger
skoda fabia 2011 1.4 VRS
car has just had a brand new genuine magnetic clutch pulley/water pump dealer part fitted only yesterday.
now the horrible rattle has gone due to play in the pulley..........but the fault code still remains,car revs to 4,000 rpm after a couple of revs (on idle) it only revs up to 3,000 rpm.
which is not right..........its going into limp mode when driving only when i put my foot down,if i drive steady it drives normal..........only when i floor it,the engine management light comes on,cars in limp mode,checked all the fuses inside the car,and under the bonnet ,checked the wiring what i can see for anything visible ............i need some help please.
cleared all previous  faults , scanned again .......this is what i get.
Chassis Type: 5J-SK25 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 44 56 77
VIN: TMBFP65J6C3028320   Mileage: 151050km-93858miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAVE)       Labels:. 03C-907-309-V1.clb
   Part No SW: 03C 906 027 CE    HW: 03C 906 027 CE
   Component: 1.4l R4 TSI   H15 9971
   Revision: L2H15---    Serial number:
   Coding: 00250012000400000000
   Shop #: WSC 26052 210 101835
   ASAM Dataset: EV_ECM14TSI01103C906027CE 001013
   ROD: EV_ECM14TSI01103C906027CE.rod
   VCID: 66C9A5D6997C637F03-8032
6 Faults Found:
4745 - Magnetic Clutch for Supercharger
          P10AD 00 [039] - Open Circuit
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 151059 km
                    Date: 2019.10.09
                    Time: 16:12:26
                    Engine speed: 702.00 /min
                    Normed load value: 15.7 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 84 °C
                    Intake air temperature: 37 °C
                    Ambient air pressure: 980 mbar
                    Voltage terminal 30: 13.735 V
                    Unlearning counter according OBD: 40
                    Mass flow through throttle valve: 8.1 kg/h
                    Median injection timing: 0.939 ms
                    Engine operating condition: Idling
                    Engine operating condition-Test_Program_Channel 87: 5
4747 - Magnetic Clutch for Supercharger
          P10AC 00 [038] - Short to GND
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 151059 km
                    Date: 2019.10.09
                    Time: 16:12:58
                    Engine speed: 698.50 /min
                    Normed load value: 15.3 %
                    Coolant temperature: 85 °C
                    Intake air temperature: 38 °C
                    Voltage terminal 30: 13.593 V
                    Median injection timing: 0.924 ms
2799 - Bank 1: Camshaft A (Intake)
          P0010 00 [039] - Position Actuator Malfunction
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 151059 km
                    Date: 2019.10.09
                    Time: 16:12:22
                    Engine speed: 694.50 /min
                    Voltage terminal 30: 13.758 V
                    Median injection timing: 0.933 ms
2985 - Solenoid Valve  for Boost Pressure Control (N75)
          P0243 00 [039] - Malfunction
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 151059 km
                    Date: 2019.10.09
                    Time: 16:12:22
                    High fuel pressure: control deviation: 0.0255 MPa
                    Charge air pressure specified value: 398.05 hPa
                    Charge press. ctrl.: spec. value: 5.1 %
                    Status of error conditions of charge pressure control diagnosis: 0
                    Status adjust recovery conditions of charge press ctrl diagn: 80
4236 - EVAP Purge Control Valve (N80)
          P0444 00 [039] - Circuit Open
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 151059 km
                    Date: 2019.10.09
                    Time: 16:12:22
4270 - Turbocharger Bypass Valve Control Circuit
          P0033 00 [039] - Malfunction / Open Circuit
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 151059 km
                    Date: 2019.10.09
                    Time: 16:12:22
Readiness: 1110 0101
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 052 B    HW: 0AM 927 769 D
   Component: GSG DSG AG7     421 2711
   Revision: 00042014    Serial number: CU501106245157
   Coding: 0000020
   Shop #: WSC 13765 790 00053
   VCID: 2A5111E686E4871FE7-5136
No fault code found.
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AL    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0001
   Revision: --------
   Coding: 430148DB436F00BAC22812E4C2D100811700
   VCID: 08158B6EBF28950FD1-805C
Address 08: Auto HVAC (J255)       Labels: 6Q0-907-044.lbl
   Part No SW: 5J0 907 044 C    HW: 5J0 907 044 C
   Component: Climatronic   H08 0103
   Revision: K0000000
   VCID: 2A5111E645E4871FE7-807E
Address 09: Cent. Elect. (J519)       Labels:. 6R0-937-08x-09.clb
   Part No SW: 6R7 937 087 M    HW: 6R7 937 087 M
   Component: PQ25 BCM      H30 0555
   Revision: -1------    Serial number: --------------
   Coding: 3D980B3808E9240092280E007C2B08C20040420F60000000020000000000
   VCID: 4E997D7619CC8B3F5B-801A
   Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 3211
   Serial number: --------------------
   Coding: 030000
   Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 3211
   Coding: 020000
   Subsystem 3 - Part No: 5J0 951 172
   Component: DWA-Sensor       03   03 1209
   Subsystem 4 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HORN H11  H11 9005
   Subsystem 5 - Part No: 5J0 951 172
   Subsystem 6 - Part No SW: 3T0 959 537 E    HW: 3T0 959 537 E
   Component: E221__MFL-URO  H07 0012
   Serial number: 2138399
   Coding: 810000
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 6R0 959 655 L    HW: 6R0 959 655 L
   Component: VW10AirbagT2C H09 0020
   Revision: --------    Serial number: 003GY003UR4V
   Coding: 003243
   ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4B9F7462E2DEBE173C-801E
   Crash sensor for side airbag: driver side:
   Serial number: 3495RRB405F0KSEG6G72
   Crash sensor for side airbag: front passenger side:
   Serial number: 3505RRB405B0LCOQH9G8
   Crash sensor for side airbag: rear: driver side:
   Serial number: 3515RRB405D0LCOQHH8B
   Crash sensor for side airbag: rear: passenger side:
   Serial number: 3525RRB405D0LCOQ79PB
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 5J0 920 941 F    HW: 5J0 920 941 F
   Component: KOMBI         H03 0305
   Serial number: 00000000000000
   Coding: 410A01
   Shop #: WSC 13765 031 00053
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
   VCID: 2E591DF6710CEB3F3B-807A
Address 19: CAN Gateway (J533)       Labels:. 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R7 937 087 M
   Component: GW-K-CAN TP20 H30 0555
   Revision: -1------
   Coding: 032300
   Shop #: WSC 101835 288 416835
   VCID: 70E5C38EA3B8BDCF69-8024
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 0305
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD1D1E68D64471F27-803E
Address 2E: Media Player 3 (J650)       Labels:. 5N0-035-342.lbl
   Part No SW: 5N0 035 342 E    HW: 5N0 035 342 E
   Component: SG EXT.PLAYER H13 0240
   Revision: A1001003    Serial number: 7669339803
   Coding: 010000
   VCID: 2953EEEA40E28C07EE-807C
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
   Part No: 6R0 423 156 B
   Component: LenkhilfeTRW        V277
   Coding: 11241
   Shop #: WSC 13765
   VCID: 2F6700F2EA06E23730-807A
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5J0 035 161 D    HW: 5J0 035 161 D
   Component: Radio-SWING   001 0003
   Revision: -----03S    Serial number: SKZ4Z2L1288980
   Coding: 010004000006
   VCID: 234FFCC222CE5657A4-8076
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
   Component: TELEFON       H09 2730
   Revision: 1B001001    Serial number: 00007660263875
   Coding: 0200000000010110
   ASAM Dataset: EV_UHVNA A01015
   ROD: UHVNA.rod
   VCID: 356B329A945AD8E77A-8060
End-------------------------(Elapsed Time: 02:34)---
  • Sponsor
Double/triple check fuse 28 in the cabin fuseholder.  Or just put a new one in.
Cheers il do that, let you know mate thanks.
Wino  You are a star mate, although it looked good, fuse was replaced car runs perfectly, mate I can't thank you enough honestly mate, I really appreciate your help, THANK YOU AGAIN.
  • Sponsor
:thumbup:
So i am getting the same issue with car in limp mode but getting these errors on torque app.
p0245 turbo/super charger wastegate solenoid A low
P2088 A camshaft position Actuator control circuit low bank 1 b
I checked fuse 28 and it was blown replaced it and it blew straight away. Can this be due to a wiring fault? it has been pouring it down for 8 hours constant.
Any help is appreciated. Thanks
That's what I call a quick fix! What a legend.
  • Sponsor
Yes. Generally a fuse blowing straight away will indicate a wire shorting to chassis, or water having got into a connector.
Check around and inside each of the connectors of things in the OP's fault log, they all share that power source.
