Front End Clunks
16 minutes ago, TMB said:
That's not enough to detect knackered drop links. It doesn't put the same kind of shocks or leverage through them as when the car is moving.
Yeah that's what I thought but I thought I'd have look at them to see if one of them was maybe loose or something. As per Wino's suggestion, i'l drive it down a quiet road swaying the car from side to side vigorously and listen out for clunks and report back with my findings.
Thanks again
Thanks again
Okay then, so I found a quiet car park and swung the car around from side to side and there was no noises at all. So I'm guessing the drop links are in good nick. I'm not gonna bother changing them until this noise becomes more prominent but it has been 'clunking' randomly for a couple of years now so God knows what's the culprit.
Cheers anyway for the suggestions guys
I was driving the car around town this morning and shifting between 1st and 3rd gears and it resulted in a clunk sound from the transmission area then a very loud set of clunks followed from both front wheel areas one after the other
Does anybody know what this may be?
Check the driveshafts for excessive play.
How would one check the driveshaft for play Sep?
Handbrake off, in gear, rock it back and forth, loud clicking means you need to get under it and grab the driveshafts and twist to feel the play.
The clunking sound from my car after months got to me and I changed the ARB's £3 odd each from TPS, nice, tight and awkward to get into the arches, I had to purchase the 19mm ones. Or turn the radio up.
By ARB's do you mean anti roll bar bushes or drop links?
He means the bushes as 19mm is one of the sizes.
Yes Anti roll bar bushes.
