Braking (part 2)
Okay so to my previous post about my brakes. Whats happening is if i go out on a journey and i spend a long time with out using the brake. If i was to apply the brake at a steady pace it would go down to the floor with very little braking effort but then if i take my foot off the brakes and then re apply they work perfectly? But if i keep my foot on the brake and apply pressure the pedal slowely depresses to the floor. Now ive stripped front and rear brakes. Cleaned and unseized everything and then bled up the system. The brakes are working loads better but still have this pedal issue? Theres no loss of brake fluid at all. Only thing ive noticed is the vacuum solenoid box above the drivers front top mount is buzzing? Is this normal?
Any help is greatly appreciated thank you
This is on a pd130 vrs se 2007 model thanks
  • Sponsor
You'd be a lot better off copy-and-pasting this into a new post on your other thread, that way everyone will be able to see all the information and suggestions to date.
