Headlights on 2006 Mk1 fabia
Hi need some advice please ,just bought a Fabia for son to learn in and on trying to adjust headlights found mounts broken on one.
Want to buy used one from Ebay but they are stating fit 1999 to 2004 . Ours is 1.2 comfort 2006 will headlight from Combi etc of earlier model fit ok . No info anywhere else on line .can anyone help ?
Yes, they'll fit just fine.
The headlights are the same on all mk1 Fabia models including pre/post facelift and vRS etc. Any Fabia lights on mk1 between 99 and 07 will fit perfect.
If you're buying second hand I'd recommend asking the seller if all the lugs/brackets are still intact as they're known for snapping.
Thanks for help got new headlight in good order But discovered adjuster on other headlight on dip beam doesn't work.it seems cross threaded and just turns round and round. Is it possible to strip out old damaged headlight and fix other one ??
