Clutch switch problem
When changing gear in my car the revs are taking a long time to go back down.
Its like i still have my foot on the accelerator.
Am i right in thinking its the clutch switch.
Where would i pick one up from.Car is a 2009 octavia vrs pfl
Hello i have recently changed my clutch master cylinder, there was a large plug on the side, presume for switch, Do you have to press clutch to start if you do then the switch could be ok. you will probably have to scan the car. have a look on the map to see if anyone is near you to help.
