Driveshaft removal
Hi all my driveshaft has completely gone ive ordered a replacement one but what size is the hub nut and torque bolts to remove it as i need to order a new a new socket. Octavia vrs mk1
  • Administrators
And both can be had at Halfords cheap enough. I got the laser spline set and used an extension socket 3/8.
If you need a 30mm you might as well invest in a small socket set that goes up to that.
