Single mass flywheel and clutch help!
Hi All,
About ten years ago, shortly after buying WRC 97, i bought a single mass flywheel and clutch kit from Awesome GTI and fitted it.....
100,000 miles and 10 years later and she is showing signs of being a little thin in the clutch area, slightly high biting point and a little slippy if I provoke it....
I have a vague recollection of it being a corrado VR6 or G60 clutch kit (not sure if these are the same clutch but assume it is a clutch from and O2A gearbox). I have tried to confirm this with Awesome GTI, but they have not real knowledge as they don't stock it any more....
Can anyone shed any light before i order a clutch, strip the car one sunday and find it is wrong....
Thank you in advance.
Went for a VR6 corrado clutch. Here's hoping it is right!
  • Administrators
Added all the part numbers too.
Great stuff. Thanks Dean! Will check part numbers before i strip mine down.
Yup was corrado VR6 clutch kit. Bought a Sachs. Numbers were not an exact match but it fitted fine and works well. Thanks for the post Dean.
  • Administrators
If you got time it might be worth adding the number here I can get the my other post updated too!
