Vrs tdi Milltek fitting?
So I was browsing eBay the other day and bought a Milltek exhaust second hand but never fitted, I wasn’t looking for one but couldn’t say no to the price.
so I’ve got a few of questions.
When fitting does it replace the dpf or come after?
Can I switch off the dpf with obdeleven?
Is gutting out the dpf a professional job or diy?
Will I have problems passing an mot without the dpf?
thanks in advance.
When fitting does it replace the dpf or come after? Depends on the system you bought
Can I switch off the dpf with obdeleven? No
Is gutting out the dpf a professional job or diy? Anyone could technically do it, but mapping it out will need a pro. Not recommended, because a) Greta will not be your friend anymore, and b) see below
Will I have problems passing an mot without the dpf? Yes, definitely. There's not really any point anyway, from a power gain perspective.
thanks in advance.
iirc, all the milltek ones for the TDI's are all DPF/CAT backs.
There's the one which turns it from a single rear exit to a twin non resonated and then you can have either a single exit sports with a resonated or non resonated backbox.
You'd only get a full system if you take it to a fabricators, but you run the risk of getting a hefty kick up the backside if you're caught with it either decatted or with the DPF fiddled with.
I've got the single exit SSXSK016
That's a single sided cat back system
