Engine management light
hello I have a 2007 fabia 1.2 petrol my engine management light started flashing then car lost power turned ignition off then started car again and it was fine can anyone tell me what the problem might be
There are many. many things that will make the engine management light come you. You need someone with a fault code scanner to see what the fault codes are, then you can investigate the cause(s).
