Newbie Owner - minor issues
Hi, new guy here :)
I purchased a 66 plate Superb SE L Executive 150 TDI hatchback as approved used from Skoda dealer 6 weeks ago.  Overall very pleased with the car, quite a change from my MK7 Golf GTI !   2K miles covered, and I have two issues which I need to address:
1) The chrome trim on top of drivers door is catching the rear door top trim, it seems quite a common issue on earlier Superb's from what I read.  Closer inspection and trim removal shows what looks like the whole upper door seal has moved 'backwards' towards the rear door.  I have read on here that owners have had new seals fitted.  My question is anyone had this issue sorted sorted under extended approved used Skoda warranty?  My cars factory warranty ended in October 2019, but I have approved used Skoda warranty.  I guess as it is a trim issue will not be covered now?  Anyone know the cost of replacement if not under warranty?  This issue is messing with my OCD and needs sorting before it gets worse :)   I did not notice this issue when I viewed the car, only in the past week has the trim catching started to occur.
2) Again well documented on here, an annoying rattle top centre of the dash over certain road surfaces happens, possibly from the large centre metal grill above the air vents towards the windscreen is the cause.  Anyone had managed to remove this grill and fix the rattle? Is the grill easy to remove?
My two closest main Skoda dealers are Bristol Street Skoda Darlington and Derek Slack in Middlesbrough if this is relevant.
Thanks all
Mike
Trim is one of Skoda's best warranty get out clauses.
However, you only bought the car a few weeks ago so the fault was clearly already there when you bought it.
As mentioned the fact it is a common manufacturing / design defect and therefore not wear and tear only supports your cause.
Phone the dealer ASAP. The longer you leave the harder it might get.
Check out their used car warranty here...
https://www.skoda.co.uk/owners/warranty
32529_skoda_approved_used_warranty_doc_v3.72110e7831bce3d9427fded26bdd2652.pdf
"Bodywork" and "bodywork components" are excluded, but only those parts that require adjustment. Door seal trim should not need adjustment.
Let us know how you get on.
Edited by silver1011
Straight back to the supplying dealer with that one, Mikes.
@Mikes_Superb
Re: 1 - door trim. This is a service campaign and should be addressed by the Škoda dealer when it is serviced or brought to their attention.
Chances are it might have been addressed at some time already but I've seen posts in this forum where some dealerships have made a mess of it by not carrying it correctly.
The trim needs to be removed (and replaced if the trim has creased) and should be realigned then secured back in place using glue pads supplied by Škoda for this very purpose.
It should not be a warranty matter as it is a known manufacturing defect of the early Superb III. AFAIK the Škoda service bulletin reference is 64E3.
Thanks for the replies, all useful.
I popped along to my local Skoda dealer yesterday, put forward my case and showed the trim issue.  To their credit they knew of the issue - no denying they hadn't seen it before - knew of the TPI (thanks BillyJim for exact ref) and ordered the required parts there and then.  Car goes in Friday morning this week before work (providing the parts arrive by then), collect after work hopefully with the new parts fitted as per the TPI.
I'll update how I get on with this.  Have a great NYE 👍
What about the dash rattle?
Apologies for the delay, a quick update. My local Skoda dealer removed and refitted the top door seal along with a new polished trim top piece.  I am keeping an eye on the situation, its been 3 weeks now seems to be OK so far - touch wood.  This work was not under warranty due to it being a known TPI.
The dash rattle I located myself, and applied discreetly some anti-rattle tape (you cannot see it).  The source of the rattle was from bottom left plastic instrument binnacle, it was touching the main dashboard, hence the noise appeared to be originating from around the central vent area in the dashboard.  I leveraged the binnacle gently using a trim tool and 'padded out' the binnacle gap against the dashboard with the anti-rattle tape (maybe 1/4 mm thick).  This has cured 75% of the rattling, I may see if I can improve upon this further at some point, but its at a level now of infrequent rattling that does not get on my nerves!
  • 7 months later...
Sorry - thread revival.
I'm currently chasing down a couple of rattles, one somewhere in the boot area and proving very good at hiding, and 1 that stops when I touch the instrument binnacle surround.  Any hints and tips on removing it?  Mines the VC cluster  (not sure if that makes a difference or not).  Cheers.
Edited by JBD1974
