Factory values for instrument cluster lighting skoda octavia mk3
Hello,
as the title suggest i own a mk3 skoda octavia.  I always annoyed me the way the lighting system worked in the instrument cluster.
So i searched on the web to find some VCDS tweaks to make it better. I found one and change the settings with in my car.
Unfortunately the tweaks do not work as intended ad all.
So i am looking for someone that can give me factory settinging for :
-dimming_characteristic_curve_adjustment_clock_dail_day-x1 through x6
-dimming_characteristic_curve_adjustment_clock_dail_day-Y1 through Y6
-dimming_characteristic_curve_adjustment_clock_dail_night-x1 through x6
-dimming_characteristic_curve_adjustment_clock_dail_night-y1 through y6
thanks in advance
As you've mentioned VCDS, did you check your coding log? It should show every change you've made...
Thx i forgot about that 😅  now i need to try again
