Eibach Spacers
After a bit of guidance please, i am about to order a set of Eibach pro springs and  i noticed they also do spacers, what is the best size to get, they do 5mm 8mm 10mm 12mm 15mm 18mm and 20mm i am currently running on 19" wheels and obviously don't want to go to wide in-case they rub, what size do you guys use or recommend?.
Thank you in advance
Chris
  • Sponsor
10mm front and 15mm rear is always a popular option.
Let us know if we can be any help with info or prices.
Damian @ DPM Performance
Thanks Damian
 I never knew you existed (and you are close to me :) ).  Do you fit as well or just supply?. I am looking at a few things at the moment.
Chris
  • Sponsor
Hi Chris,
Just supply.
I have been tempted for a while with spacers as my 2010 fl Octy vrs could definitely benefit from the wheels filling the arches a bit more. I’ve been a little put off by all sorts of horror stories with them causing issues tho. What’s your feedback on them Damian as someone who sells them?
Also out of interest could you DM me a price for 15 rear and 10 front Eibach. Cheers
Edited by Pods
Had a set of 15mm hubcentric spacers on the back of my scout for Many years with no problems whatsoever.
  • Sponsor
As long as you stick with good quality hubcentric spacers and use the correct length bolts you shouldn't have any problems.
Price PM'd.
Am i correct in thinking you need longer bolts for any size spacer say 10mm or less ?
