VC retrofit
To change the 5F to get the digi instrument panel tab you need to change
menu_display_Display_Configuration: active
menu_display_Display_Configuration_over_threshold_high: active
[LO] display_configuration_0x45: active
[LO] display_configuration_0x45_msg_bus: Clamp 15
As long as you have 3Q0 Gateway.
Sasha do you know what need to be changed to make icon of the car makes move in ACC display? In mine case it all time on the lowest position but ACC itself works fine. THX
Hi, and thanks for your replies.
I have tried to change:
but i get an error: 0x00 Unknown error.
any ideas?
I don’t have ACC on my car so I couldn’t say unfortunately.
any ideas?
In 5F? What radio is fitted and what CAN Gateway do you have?
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-HGH2.clb
Part No SW: 565 035 043 A HW: 565 035 043
Component: MU-H-N-EU H54 1163
Serial number: A856I0HB013585
Coding: 03840201000000005111000200080A002F0101E441208400DE
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 CQ HW: 5Q0 937 084 CG
Component: BCM MQBAB H H36 0253
Serial number: 01001729700913
Coding: 000000000000000000000000000000000000000000000000000000000000
Shop #: WSC 33361 790 00156
ASAM Dataset: EV_BCMMQB 018001
ROD: EV_BCMBOSCH_018.rod
VCID: 09192823A8394BCE44-805C
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 3V1 955 119 HW: 3V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: 48x LL 170915 032 0121
Serial number: 00000001709130304774
Coding: 164DDD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 047 0105
Serial number: S8Y17M10D27H06M34S24
Coding: 00084D
Seat Backrest Fan 1 Front Left:
Subsystem 3 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0101
Serial number: ESE0438377
Seat Cushion Fan 1 Front Left:
Subsystem 4 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0830269
Seat Backrest Fan 1 Front Right:
Subsystem 5 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0350261
Seat Cushion Fan 1 Front Right:
Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0830266
Coding: 164DDD
Coding: 00084D
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 12061710803555
Coding: 030100345F087300EB00025E9C0F00010001070000000000000000000000
Shop #: WSC 33361 790 00160
ASAM Dataset: EV_GatewNF 013023
ROD: EV_GatewNF_VW37.rod
VCID: 3365AACB9A35611EDE-8066
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 3V0 919 719 A HW: 3V0 919 719 A
Component: E221__MFL-PR6 H02 0160
Serial number: 000000000A0378171017
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H10 9070
Serial number: 5267805604
any ideas?
Me too but i cant find clamp 15 i dont have
