DSG Gearbox Errors. Advice Needed
I am getting intermittent gearbox faults on my DSG. Do I need to worry about these or are they normal....
One garage said if you notice it and you have no dash lights it's not an issue.  I need some independent advice. Is it the start of something that could become more significant....
OBDeleven data log
Date: 2020-02-07 20:41
    VIN: nnnnnnnnnnnnnnnnnnn
    Car: Skoda Superb
    Year: 2017
    Body type: Estate
    Engine: CRLB 110 kW (150 HP) 2.0 l
    Mileage: 133166 KM
02 Transmission Control Module
    System description: DQ250-6F MQB
    Software number: 0D9300042M
    Software version: 5013
    Hardware number: 02E927770AS
    Hardware version: H54
    Serial number: nnnnnnnnnnnnnnn
    ODX name: EV_TCMDQ250021
    ODX version: 001001
    Long coding: 0014
    Trouble codes:
        P072C00 - Stuck in Gear 1
            Intermittent
        P072D00 - Stuck in Gear 2
            Intermittent
        P072E00 - Stuck in Gear 3
            Intermittent
        P072F00 - Stuck in Gear 4
            Intermittent
        P073A00 - Stuck in Gear 5
            Intermittent
        P073B00 - Stuck in Gear 6
            Intermittent
        P072B00 - Stuck in Reverse
            Intermittent
        P174A00 - Valve 3 in partial transmission 1 Electrical error
            Intermittent
        P174E00 - Valve 3 in partial transmission 2 Electrical error
            Intermittent
        P072600 - Engine Speed Inp.Circ. Range/Performance
            Intermittent
            Intermittent
        P079700 - Pressure Contr.Solenoid C Stuck On
            Intermittent
        P179D00 - Cooling oil valve Electrical error
            Intermittent
The errors have been recorded and ODBeleven picks them up as inactive. So they have occurred but arent occurring at the time.of the scan. Are you saying they are false messages?
i hope so, dealer told me he can't see any
For peace of mind, you could erase them all and then re-scan in a few days time?
Mind and re-scan with only the ignition on 😉
Cheers. I've reset already but scanned with the engine on before
It's a false alarm, typical of the DSG when scanning with the engine turned on, your gearbox should be fine.
Usually a sign of someone who spends too much time with their car and scans for faults without actually having any issue :D   (I have been guilty of that in the past myself too)
Nowadays you have to check car by self, one week before noticed that errors car had an anual service,
and dealer didn't noticed dead air qualitty sensor,
now i waitig it fourth week
On my 06 Golf I had the PRNDS flash of doom and it was stuck in first gear limp mode with no reverse
Had to replace the whole box in the end. It had done about ~125k
Sounds like a poor dealer than anything else (if the fault was there prior the service of-course).
Also, all these DIY scanning tools are good and useful when you know what you're doing, the majority of users buying and using them doesn't, they just think it's cool to replicate what they read on-line.
And this is relevant to an actual false alarm of a different car and a different gearbox how exactly?
10 minutes ago, MartiniB said:
Now I feel bad because I assume every other Briskodian is capable of reading Russian even from non translatable documents  :worried:
true
short version:
full replacement of DSG6 on 82k Km,
after lost completely power on highway, thank God one way traffic
first part only screenshots, have no idea why author didn't simple copy-paste his text
https://www.drive2.ru/l/552321800223065649
my also has reached 82k Km, but without problems, except rattles on rough roads
https://www.youtube.com/watch?v=abPGeEu9iWE
replacing oil after each 40k Km instead required 60
4 minutes ago, MartiniB said:
true
short version:
Very rare occasion, the DQ250 DSG6 boxes are almost bullet-proof. I hope the new DQ381 DSG7 in mine turns out to be as good as those in the long run.
And in any case it's not related to the OP's "issue" as he doesn't have one essentially. No reason to stress him for no reason!
  • 6 years later...
So, what was the outcome of this in the end?
I’m 100% sure it’s a result of trouble code scan with engine on. I panicked myself in the same way previously.
I did not have this. It only surfaced after a DSG oil change. Now there is some jitter and hesitation when driving off. And jitter all over the place.
That sounds more serious. Has an adaptation been done since oil change? It resets all the clutch bite points etc. if still jittery could be clutches wearing. Has it had all its dsg services at the correct intervals?
It drives pretty normally. Just more hesitant and clueless. I don't believe adaption has been done. It all started because I adhered to this interval.
I assume is 6 speed and wet clutch. The clutch material as it wears ends up in the oil. That’s why the oil and filter must be changed. As well as general deterioration of the oil. When new oil is added it doesn’t hold the same particulates and as such the clutches can slip until they are adjusted via adaptation.
If it’s just that the gear changes are a bit hesitant or change up/down a little unexpectedly it may well be because it has had the adaptation done and it needs time to relearn your driving style.
