Zero vacuum pressure
My 2013 fabia vrs estate is running a little off at the moment. Slightly erratic idle, seems a bit hesitant on pick up, gearbox seems a bit slow to react, so I suspected a possible vacuum leak. When I've connected  my gauge up to the engine I am getting absolutely zero movement on the needle unless I blip the throttle and then it moves slightly into positive pressure. Do any of you fine chaps have any idea where to start looking first?
I would if he hadn't gone to the match.
