Fitting Rear Door Stone Chip Foils
Can anyone supply the Skoda fitting instructions for the transparent stone chip foils that go over the rear door / wing areas of the Yeti.
There are previous references to these instructions in the Guides section (from The Great Yeti) but the link for his PDF no longer works.
Are they not helicopter tape?
Make sure they go right over the edge.
Does this help?
That must be the same method as Skoda's  - there was brief reference to soapy water in the old post, but this explains it perfectly.
Many thanks, Urrell.
Hi PlinY
Sorry the original link has failed 😞 No idea why but here is the link again:
LINK
I will post an update in original post in the Technical Guides section - Thanks for the "Heads Up" about the link not working!
Hope this helps............Tony (Great Yeti)
^^  Very generous of you to reinstate the link, Tony.  A long while since the topic last came up, but it'll surely do so again.
(Nice to see the Wobbly Tank, too 😎 !)
Thanks for reviving the link, Tony. The power of the forum never ceases to impress.
