Lower control arm bush
Hi can anyone share the part number of solid front lower control arm rear bush, The lemforder oval ones with part number 1J0 407 181  failed after 40K miles. Is the part number 8N0407181B which is not looking oval the right one?
Thats the right number
Thanks mate, will the round one fit where the oval ones go?
The number is correct, but that prefix 8N0 does not look right, I normally use 1J0 prefix units. The 8N0 should be for the TT alloy front lower arm, which do you have on your car?.
Have the stock control arms, I don't want to use the stock bushes with slots in them. Looking for a solid bush
