Engine stutter
Hi all
Anyone else noticed a issue when starting up from cold engine stutters then fires up
after that turns over normal
glow plugs ?
fuel line supply ?
Yes I had that for a while then had a glow plug fault. Changes all of them and its been fine since.
Thanks for that
I seem to be only getting it now n then must be intermittent issue then
Typically, the glowplugs should probably be replaced around 60k miles, but they should be good up to about 80k without replacement.  All depends on your driving style.
