Don't work all bulb
my octavia has problems. lamps all burn through one. one dimension, on the other hand one main light and with all the same, with the rear too. Tell me what could be the problem. all fuses are normal. thanks
Appreciate you’ve tried to put that into English to ask for help for an issue but to me that doesn’t make enough sense to be able to answer your question!
2 hours ago, phil08 said:
Я благодарен вам за то, что вы пытались перевести это на английский, чтобы попросить о помощи по проблеме, но для меня это не имеет достаточного смысла, чтобы ответить на ваш вопрос!
Easy, all bulbs work incorrectly. I find problem, now all perfect. I replace 1 fuse 30A, but outside fuse fine, and inside one legs is damaged.  Thank you so much for your  answer.👍👍👍
