2007 BMN PD170 ally inlet conversion
Inlet manifold has failed leaking oil and stopped my DPF from regen, coil light on, limp mode permanent.
 DPF fill is 64%, car is parked and looking at inlets.....  new plastic orig from dealer is 650+vat + fitting,  found a dark side developments ally conversion with flap removal and need advice..
found this article on another page as my concern is the vacuum pipe and ECU ?
https://forums.seatcupra.net/index.php?threads/bkd-inlet-manifold-on-bmn-pd170.420277/
will it fit my model, what’s risk any advice welcome
