Estate number plate light replacement?
Drove my new car for the first time this morning, nice little yellow warning triangle on the dashboard, number plate light out.
The left one still works, the right one doesn't, can anyone recommend some straight swap whiter replacements please, as the current working one is very orange.
Failing that, I guess any 501 bulb will do? Thanks.
i think i replaced mine directly with skoda rapid led ones. it needed a tiny bit of filing of a tab with a craft knife if i remember correctly. i will try and find the post
here you go!! (part number and photos included) I did need to code with obd11
O3 LED number plate replacements
Edited by encephalopathy
I have Carista rather than OBD11, would I be able to code them in with that instead?
As a side note, I found a bulb, and when I went to replace the broken one, it had started working again...
Edited by broona
sorry - never used carista so i don't know
I used these - No coding, direct replacement, no errors (Aftermarket - not genuine)  LED Number plate lights
