clutch sticking
hi can anyone help me the clutch peddle keeps sticking and it gets stuck in gear have to switch engine off and try and pump the peddle anyone had the same problem or have any advice thanks
You need to change the clutch set. It wont be a cheap fix. the clutch cilinder is done probably. the clutch last about 200.000km most, and then it start to make noise, stick, rattle, wobble when taking off etc.
Hi thanks for your reply car just packed in had to get towed to a garage will know on Monday what the damage is
Ok give us feedback and good luck
