Incorrect Date Stamp on Fault?
Ran a scan on my Skoda Octavia Estate 2.0Tdi to do a service regeneration on it. Worked up to a point but that is another question for another day.
Before I could run the scan VCDS came up with update 20.4.0 which downloaded no problem and installed correctly.
However in a later scan it  has come up with a fault date as: 2047.04.09 which given that Ross Tech is a US Company would give a date of 9th April 2047.
Anybody have any ideas about the date / time logged in the ECU?
1) I have posted on Ross Tech Forum
2) Looked at the archives but answers don't ring true with me at the moment
Here is the part of the Scan:
Thursday,02,April,2020,17:22:30:08428
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.0.1 (x64)  HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: TMBGE21Z7C2140161   License Plate: YR12 FEP
                Address 01: Engine       Labels: 03L-906-018-CFF.clb
Control Module Part Number: 03L 906 018 C    HW: 03L 906 018 BR
  Component and/or Version: R4 2.0l TDI   H24 9978
           Software Coding: 00190012042500080000
            Work Shop Code: WSC 22007 210 00000
              ASAM Dataset: EV_ECM20TDI01103L906018C 003008 (SK35)
                       ROD: EV_ECM20TDI01103L906018C.rod
                      VCID: 2A0D056D4C7D279B2D6-807E
2 Faults Found:
4891 - EGR Valve (N18)
          P0403 00 [237] - Malfunction
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 3
                    Mileage: 312472 km
                    Date: 2047.14.09
                    Time: 16:04:05
                    Engine speed: 789.50 /min
                    Normed load value: 45.1 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 49 °C
                    Intake air temperature: 21 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 13.960 V
                    Unlearning counter according OBD: 40
                    Air mass: actual value (mg/stroke): 413.7 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                    EGR Solen.val.: actual value: 83.59 %
                    EGR valve: offset closed: -4.99 %
                    Actuator for high pressure EGR: status-Bits 0-7: 0
                    Actuator for high pressure EGR: status-Bits 0-7: 55
                    Actuator for high pressure EGR: status-Bits 0-7: 7
                    High press EGR actuator: actual unconditioned volt val: 1642.0 mV
4892 - EGR Valve (N18)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Mileage: 312472 km
                    Date: 2047.14.09
                    Time: 16:04:05
                    Engine speed: 778.00 /min
                    Normed load value: 42.7 %
                    Coolant temperature: 50 °C
                    Voltage terminal 30: 14.060 V
                    Air mass: actual value (mg/stroke): 296.6 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation: 15.00 %
                    EGR Solen.val.: actual value: 40.31 %
                    High press EGR actuator: actual unconditioned volt val: 2941.0 mV
Readiness: 1 2 0 0 1
                Address 01: Engine  (03L 906 018 C)
18:24:09
  IDE03270   Exh.gas temp.sen 1: unconditioned voltage 4965.6 mV
  IDE03271   Exh.gas temp.sen 2: unconditioned voltage 0.0 mV
  IDE03273   Exh.gas temp.sen 3: unconditioned voltage 4354.6 mV
  IDE03275   Exh.gas temp.sen 4: unconditioned voltage 3968.6 mV
Yeah 9th April 2047 is the date we will be allowed to go to a pub for a pint according to Google.:notme:
Perfectly normal on this generation of car.
The only module that might know the date is a headunit with GPS, other modules will frequently give mad dates for fault codes. The mileage is generally a better way to decide if a fault is current.
