Door window regulator replacement
I would appreciate any one with experience of replacing the internal door panel with window regulator on a 2006 year front near side .
I have been looking on various web sites and wondered if anyone has experience on how to identify if the  steel panel is the same spec as original and not a thinner gauge metal.
Also any info on the new rivet size/length would be appreciated, I understand I need too get a lazy tong riveter to install the new rivets and plumbers gold sealant.
Thanks in advance
martin.
Edited by kentdale
miss spelling
The pop rivets for steel carrier to door are part number N91078801  6.4X10.0mm. There are 10 rivets in each front door.
The pop rivets for regulator to steel panel are part number N90765701 (these also fit the speaker to steel panel). 4.8x15mm
The panels are all the same thickness.
Edited by TMB
  • Sponsor
By an ex Skoda Master Tech. :)
He pops in occasionally, so might be able to assist online with any queries.
Thanks TMB, am I correct in assuming that the parts numbers are Skoda dealers ones.
Thanks also Wino, just watched your spot on guide , much appreciated both.
Martin.
Yes, they are Skoda part numbers.
