Help.
Hi everyone.  I have a skoda octavia mk 3 and up dated my info system to Amundsen mib 2 with a new screen, I have the component protection taken off and all works fine except 2 things. The Voice button, when pressed says, You can activate with a code from your dealer, and i remember reading that the usb port has to be changed.
Can anyone shed a little light on this for me and if i do need a new usb which one do i need .
Best wishes
Rob
Who did the radio work for you? CP removal isn’t the only thing that needs doing so I assume someone outside Skoda has re enabled the features for you? They haven’t done the FeC for the voice activation.
New USB part number is 5Q0035726E.
Hello . Thank you for that. Yes a company done it for me in Birmingham . They are really nice people, I can pop back to them and tell them what you said and hopefully have it all working. Its a really nice unit, i will try and pick up a new usb now that i know which one,, do you know if they are easy to replace .
Rob
Yes. Remove the screen, pull the climate panel out, pull the USB panel out and unclip the USB.
wonderful . i will do it as soon as i can pick up a new usb. Thank you so much .
Rob
Hi. May i ask if you know the reason my mode sw on the console doesn't work after my upgrade.
Rob
How has this work been done for you, have you visited someone and had someone code it or have you bought a radio that is CP free and hacked and fitted it yourself?
I bought the radio, then went to a place in Birmingham that codes radios for Audi Vw, ect, They took the protection off for me.
It all works except for voice and mode. You told me the correct usb to get so that's fine.  They are going to activate the FeC for me. Is there anything i need to have done to activate the mode sw. Rob
Also im a little confused as to which satnav card i need as there are so many with different numbers, do you happen to know the number of the one i need .
Rob
Driving mode is usually Gateway related, has the CAN Gateway been changed? Have them check the coding on your radio again to make sure it’s all setup for drive mode as there is some coding in there. If it’s a MIB2 Amundsen the part number for the SD is 5L0 051 236BJ
Will do thank you, and thank you for the number of the card i need, wonderful. Ill keep you informed of how it goes.
Many thanks
Rob
Hi can anyone tell me the part numbers i need please. I have a skoda octavia mk 3 1.6   2013 diesel and i want to update my steering wheel for the multi functional one. presently i have a 4 spoke, 3 or 4 spoke would do. I need to know so that it will fit and the centre with the air bag will fit.
Many thanks.
Rob
No worries, I would get a scan done of your car first before you worry about part numbers for steering wheels as if the CAN Gateway does need changing it’s more ODIS work to be done before the wiring is sorted.
ok will do  thanks for that i will get a scan done.
Rob
I have now got a  copy of a complete scan how can i find out which steering wheel with buttons i need .
Rob
Post the scan up here, if not the whole scan then 16 steering wheel controller and 19 CAN Gateway at least. I can check the part numbers against a list of part numbers with with listed features and see if you need to change any other hardware.
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 AL    HW: 5Q0 953 549 A
   Component: Lenks. Modul  007 0070
   Revision: --------    Serial number: 10091304220612
   Coding: 1600
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_SMLSKLOMQB 009001
   ROD: EV_SMLSKLOMQB_020_VW37.rod
   VCID: 000FAC4D9BA0638602-8054
No fault code found.
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 K    HW: 5Q0 907 530 D
   Component: GW MQB Low    123 1144
   Revision: --------    Serial number: 0000973662
   Coding: 030000040B087300EF0002481C0F00010001000000000000000000000000
   Shop #: WSC 73430 790 00114
   ASAM Dataset: EV_GatewLear 009013
   ROD: EV_GatewLear_009.rod
   VCID: 397901A9B8FAF24E05-806C
   Alternator:
   Battery Monitoring Control Module:
   Subsystem 2 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 5523651303
Hope thats ok .
Looks like you at least need a new CAN Gateway unfortunately along with the airbag wiring and steering wheel. If you want to do this I do have (somewhere) a High 5Q0 Gateway which is correct for an Octavia and removed from my car. This will need CP removal at least to work in your car before you worry about a steering wheel. PM me for more details on that if you like.
Thanks for that, it seems such a lot to do just for a mfsw, is there lots of programming to do or is it just a case of plugging it in and fitting the wheel . ?
Once the Gateway is done and the CP dealt with and the drive mode programming reloaded onto it it’s just the airbag loom and the wheel buttons to add afterward but yes, it is a faff.
Thanks for that . I am from the old school so how do i private message you.
Rob
I have had the cangate fitted to the car, component protection has been activated, removed , All works except for VOICE,and Driving mode, am i missing something. It has all been done with the correct programming software.
Any ideas.
Rob
Also the satnav sd card says it sees it but says navigation data in infotainment  system not valid, check data . Any ideas . Rob
Voice FeC is in the radio rather than the Gateway, was the drive mode issue solved with the old Gateway before the new one was installed? Have you updated the navigation system at any point? Again, have the FeC checked. Navigation and Voice issues shouldn’t be related to the Gateway itself, any errors when scanned?
The drive mode was working till i upgraded the infosystem then it just stopped, same for the voice control,  I dont know to update the satnav card, do i have to update the satnav sd card .
Rob
Is the FeC in the programming software ?
