repeated EGR AND G42 FAULTs
Hello,
Skoda ocativa 1.6 FSI about 107k had an EGR fault code often every 50- 200 miles. I had an EGR valve replaced with genuine but the fault code still keeps coming at the same mileage interval after clearing it. Some drop in mileage when this happens but i am not completely sure.
Now it also a G42 sensor fault code which comes with EGR fault code. I had a full scan have only the below faults.
I wonder if G42 sensor actually is faulty that's why  EGR fault code comes up as I already changed the EGR valve?.
001025 - EGR System
               P0401 - 002 - Insufficient Flow - MIL ON
             Freeze Frame
                    Fault Status: 11100010
                    Fault Priority: 0
                    Fault Frequency: 16
                    Reset counter: 255
                    Mileage: 171129 km
                  Freeze Frame
                    RPM: 2080 /min
                    Load: 50.2 %
                    Speed: 41.0 km/h
                    Temperature: 84.0°C
000274 - Intake Air Temp. Sensor (G42)
               P0112 - 001 - Signal too Low - Intermittent
             Freeze Frame
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 95
                    Reset counter: 255
                    Mileage: 171313 km
                   Freeze Frame
                    RPM: 3200 /min
                    Load: 34.9 %
                    Speed: 105.0 km/h
                    Temperature: 87.0°C
Yesterday again had the same faults:
001025 - EGR System
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 31
It appears that Air intake sensor fault comes after EGR, But I note frequency  is 31.
I am thinking of to start with changing air intake sensor . Anyone has any thoughts to resolve /investigate?
